Best way to free stuck 1946 A engine
CR's
08-30-2007 16:23:42
I just brought home today a model A serial # 564790. Engine is stuck. I filled the cylinders with diesel fuel. Any other suggestions??
Mike M
08-31-2007 07:33:11
 Re: Best way to free stuck 1946 A engine in reply to CR's, 08-30-2007 16:23:42
I have unstuck several and then was able to get them running without much trouble. But some will never budge and then you have to tear them down and sledge hammer the pistons out one at a time.
I pull the valve cover and remove the rocker arms and push rods. This prevents them from damage if a valve is stuck when/if it turns over. I then put some favorite lube on the valve stems and proceed to see which ones are stuck. A plastic dead blow hammer works good. If they are free and bounce back all is looking alot better. Last one I did I unhooked the intake and ex. pipes and filled engine as full as I could for a week of soaking. I then pulled out the spark plugs and then chain a large bar onto the fylwheel or maybe better yet I used a comealong and hooked it to a chain looped through one of the holes in the fylwheel then wrapped the chain over the top then down around and ended up back at the drawbar frame. Then I simply tightened up the comealong and it started to move. Then I keep working it back and forth until it would go all the way around. This last one had a valve that would move but was stuck down. I was able to just tap it up with the piston and then keep working it back and forth until it freed up too. After it is all free and moving make sure the engine has oil,put the valve train back together,leave the plugs out and disable the ignition ! then tow it around in gear to pump out the rest of the oil and junk in the cyls. I even poured some gas in them to flush it out. Then back to getting the ignition working and the carb. and then fire it up.
teddy52food
08-30-2007 19:45:09
How long ago was it running? How long has it been stuck? If it has been stuck for years, plan on taking it apart.
CR's
08-31-2007 18:21:30
 Re: Best way to free stuck 1946 A engine in reply to teddy52food, 08-30-2007 19:45:09
The man who I bought it from claims that it had sat 6 yrs.
Bison
08-30-2007 19:17:51
blow the diesel fuel out, and fill her up with coca cola. it will foam the rust right out of there, keep repeating over a couple of days.
It works, i done it on several oldies, did the trick every time. You still have to take the motor appart,cause the rings will most likely be rusted in the ring grooves.
mjbrown
08-31-2007 10:10:49
 Re: Best way to free stuck 1946 A engine in reply to Bison, 08-30-2007 19:17:51
That's one I haven't heard before! Can you use phosphoric acid so you don't have the sugar in there? Made just use diet coke.
RobMD
08-30-2007 18:50:01
Park it upwards on a hill and fill the cylinders with ATF
P Browning
08-30-2007 16:43:15
Plan now to take the engine apart! It is probably the way which brings lowest risk of damage to the parts. (PatB)
