6V cutout relay
mmm....deere
08-30-2007 08:25:15
Anyone have any experience using the 6 volt cut out relay from tractor supply co.? Says it's for case & m-h tractors, seems like a cout pout is a cut out. I'd like to use it on my JD M.
J Chantry
08-30-2007 19:07:44
 Re: 6V cutout relay in reply to mmm....deere, 08-30-2007 08:25:15
Just bought a 6 volt cut out relay Part # 236465 from Tractor Supply Co for a JD-M that I am restoring. Have not started tractor to see if it works yet. Instead of trying to cutoff old relay from the metal backing plate, I made a new backing plate and drilled two holes to mount the new relay, also bent the relay mounting tangs so would fit in instrument panel opening.
Should work fine.
55 50
08-30-2007 09:26:11
Well, "a cout pout is NOT a cut out", but I know what you mean :) A 6 volt cut out is not color sensitive, it will work on any make of tractor that has a 6 volt system and uses a cut out. Except maybe the reason for the "discrimination" is the mechanical configuration is specific, i.e. the shape and location of mounting holes, etc.
mmmdeere
09-05-2007 07:01:51
 Re: 6V cutout relay in reply to 55 50, 08-30-2007 09:26:11
Put the relay on it this weekend, works great! mounted it in the battery compartment where the bolts hold the instrument panel to the frame. Not JD original, but cheap & easy!
