830 3 cyl - Hey Tx Jim
Michael Sheik
08-30-2007 04:52:33
I am not as mechanic sharp on these things as you and others so what specifically are you talking about when you say I may have a leaky rockshaft valve? Where is the valve located on tractor? Before I bought this thing JD had done some work a couple different times on the 3 point and I can see what looks like a new part on outside located just above and maybe a little aft of the PTO engage lever. I was thinking it was some sort of bypass valve assy as it has a center stud and nut and looks to be adjustable. Would this be what you are referring to?
Tx Jim
08-31-2007 04:39:43
 Re: 830 3 cyl - Hey Tx Jim in reply to Bob Nelson, 08-30-2007 04:52:33
Michael,it's been 20 years since I worked for a JD dealer so I'm relying on my memory/no tech manuals. The 820/830 & early 2040's are unique as they're open-center hyd's. The rockshaft valve is inside the RS housing on RH side. Remove hyd oil filler cap and with engine running/3pt raised,look inside hole with a flashlight for dripping/spraying oil. If valve is the problem the RS housing will have to be removed. Also thermal relief valve could be the problem. I think the valve by pto control you are refering to is a relief valve. Tx Jim
