4020 POWER SHIFT HYDRO PUMP GOING OUT
j kemp
08-29-2007 20:17:23
Our 4020 hydro pump is making a lot of racket and it is not the aluminum blocks ,, Further the tranny is not holding adequete pressure at 2200 rpm that the power shift suggests , when hot,. however all componets seem to work OK but pressure is waning ,, Like to finish hay season before taking her apart ,, Any advice , Thanx Jim
J kemp
08-30-2007 20:04:28
 Re: 4020 POWER SHIFT HYDRO PUMP GOING OUT in reply to j kemp, 08-29-2007 20:17:23
OK , the front hydro pump is supplied by a tranny pump ? Correct , making two pumps traversing all the oil? . With tranny geting 1st priority . Correct? Could be the screen, ., Havent cleaned that in a few years . Thanx Guys
ET
08-31-2007 06:57:50
 Re: 4020 POWER SHIFT HYDRO PUMP GOING OUT in reply to J kemp, 08-30-2007 20:04:28
There is a filter bypass valve behind the rear hydraulic filter, when you drain the oil to check the suction screen pull the valve out and clean it to make sure it is not stuck open.
G/MAN
08-30-2007 07:33:23
MSM is right and the transmission pump also supplies charge oil to the main pump, so a weak tranny pump can starve the main pump for oil, causing cavitation noise that might be what you're hearing.
MSM
08-30-2007 05:12:42
Have you checked the fluid level,and checked/changed the filters and suction screen. The powershift pump is a seperate pump on the front of the trans,but clogged filters can cause low shift pressure as can an internal hydraulic leak lowering charge pressure.
