5310 injector pump problem?
Gene Davis (Ga.
08-29-2007 18:43:47
At the golf course where I work we have a 5310 JD tractor that cranks good 95% of the time. Sometimes when you use it and shut it off then come back to restart it it will not crank. Starter grinds away and no smoke or any action at all. Took VOM and test light and touched to the shutdown solenoid and have 12 Volts to the terminal on the outside of solenoid. Yuo can take a rag with just a whiff of gasoline on it and hold it over the air cleaner and it will fire right up and run just fine for several days or a week and then it will do this again. Could the shut down solenoid inside the injection pump be hanging, or something like that. Does the pump have to come off to change it or is the entire pump headed south? THanks Gene Davis
K.B.-826
08-29-2007 19:16:39
 Re: 5310 injector pump problem? in reply to Gene Davis (Ga.), 08-29-2007 18:43:47
Might want to check with the dealer. I seem to remember that those tractors had issues with fuel draining back to the tank while sitting. There was a check valve that could be installed in the outlet line at the bottom of the tank.
Gene Davis (Ga.)
08-30-2007 12:01:33
 Re: 5310 injector pump problem? in reply to K.B.-826, 08-29-2007 19:16:39
The tractor cranks well after it has sat. No problem with fuel to the pump once it fires the first time. It will catch right up when you getr it cranked. No sputter or miss like it is not getting fuel. Just has to have something to crank it off.
Gene Davis (Ga.)
08-30-2007 11:57:32
