Dent in carb float. Still usable? DLTX 67
Randy G.
08-29-2007 15:55:03
Its off a 49 JD B. No leaks but can I safely use a dented carb float or would I be better off just replacing it? If I Do replace it, wheres a good place to get a new float from? I"m puting a new kit in the carb. Thanks for any advise.
Randy G.
old
08-29-2007 17:28:39
 Re: Dent in carb float. Still usable? DLTX 67 in reply to Randy G., 08-29-2007 15:55:03
I've found more then one dented float in carbs when I have opened them up. If the dent dosen't cause it to hang up any place you should be just fine using it.
CENTAUR
08-29-2007 17:27:03
I assume it is a brass float.Unsolder the small hole and blow air over it till the dent pops out again.Do not direct the air into the hole but over it.Then resolder the hole. CENTAUR
