1950 Model A
Glen in Michiga
08-29-2007 15:48:29
I'am hooking up my lights and gauges. I have a 6 volt generator and 6 volt bulbs but I've been using a 12 volt battery to start the tractor. Should I use the original stile 2 6 volt batteries or can I get the generator changed over to put out 12 volts and change the bulbs and regulator? Thanks again
Len Bull in NC
08-30-2007 09:12:19
 Re: 1950 Model A in reply to Glen in Michigan, 08-29-2007 15:48:29
Dont forget..positive ground!!
Glen in Michigan
08-30-2007 02:25:54
I put a tester on the generator and it only showed a peak of 6 volts at the regulator. Did I check it wrong?
DickD
08-29-2007 18:28:11
Glen; Ronco is right on the money with the one 12V battery. It is also a good idea to get as high a cold crank battery as you can buy. It sure helps starting in cold weather.
ronco
08-29-2007 17:19:16
1950 A has a 12 volt system. The original 6 volt batteries were wired in series making 12 volts. A single 12 volt battery will work fine. Your tractor should already have 12 volt bulbs, starter and generator.
