How do you adjust throttle friction on JD 4010?
Stewart Patters
08-29-2007 09:46:40
vf4x.
08-30-2007 03:13:55
 Re: How do you adjust throttle friction on JD 4010? in reply to Stewart Patterson, 08-29-2007 09:46:40
I recently replaced this friction on my 3010. The replacement is made of teflon or nylon and only compresses when I try to tighten it. Has anyone had a similar problem?
Bob
08-30-2007 07:09:45
 Re: How do you adjust throttle friction on JD 4010? in reply to vf4x., 08-30-2007 03:13:55
Yes, that's a side-effect of the elimination of the asbestos "brake lining" used originally.
Stewart Patterson
08-29-2007 19:35:39
It's a gas 4010. Thanks for your time
ET
08-29-2007 10:47:06
Cap screw 13 ajusts the friction.
Stewart Patterson
08-30-2007 17:14:17
 Re: How do you adjust throttle friction on JD 4010? in reply to ET, 08-29-2007 10:47:06
Thanks a million.
Stewart
Bob
08-29-2007 10:08:32
 Gas or diesel... in reply to Stewart Patterson, 08-29-2007 09:46:40
Should be the same... Bolt, Key #13, at the base of the steering column.
Third Party Image
(The friction pad, tucked inside the tube, is Key # 12.)
Stewart Patterson
08-30-2007 17:11:13
 Re: Gas or diesel... in reply to Bob, 08-29-2007 10:08:32
Thanks a million. Sounds like something that even I can do.
Stewart
