Big B and Little B
tfaber
08-29-2007 09:08:17
My dad farmed in the 60"s and he always talks about farming with the "Big B" and "Little B". He says the "Little B" was a smaller version of the "Big B". I have shown him lots of pictures of other models thinking that this was his "little B", none of them have been it. Does anyone have an idea what my dad might be talking about? Did John Deere make a smaller version of the B and still call it a B?
tfaber
08-30-2007 10:00:54
 Re: Big B and Little B in reply to tfaber, 08-29-2007 09:08:17
He always talked about a size difference, and never a power difference. When he was ten he said that he was able to almost see over the hood and he was even strong enough to start it and my dad is not a large man. You guys have made some good points. Thanks for your input!!
CLW
08-31-2007 14:58:48
 Re: Big B and Little B in reply to tfaber, 08-30-2007 10:00:54
Find out what year it was when your dad was 10. You would know the tractor would have to be no newer than that year. You say he was "strong enough to start it" so I take that to mean it was a hand start. Most likely late 30's early 40's model. Ask if the airstack and muffler was side by side or in line with each other. That would make it a 38 or older or 39 or newer. Also ask him if that was the Little B or Big B he started at age 10. The 47-52 B not only had more power it was 6.75 inches longer and 2.6 inches taller at the radiator than the earlier styled B.
CLW
08-29-2007 20:28:38
I think he was talking about the early styled and late styled. The early styled (up to 47) had 18 PTO/belt and the late styled (Starting in 47)had 27 PTO/belt. Show him a picture of those two and see what he says. There was a world of difference in the power of these two tractors.
Duane Larson
08-29-2007 14:51:59
tfaber,
Your Dad might be referring to some advertising done by Deere for the 1941 model year - 6 speed transmissions were added, and the compression ratio for the B was increased, providing more power, hence the "Big B". So, if he is speaking of styled B's, those (4-speeds) from 1938-1940 would have been the "little" B, and after (s/n 96000, 1941) would have been the "big" B. Just a guess. Maybe he put a power block in one of them, or added high compression pistons or a Heisler head, or ..... .
Loren in Florida
08-29-2007 11:16:31
Older unstyled were short frame. Later unstyled were long frame, same as the A, so mounted equipment was interchangeable. Don't remember the year of the change, but sure someone will jump in with that info.
Ravgardner
08-29-2007 10:31:17
Well, if you put a 45 or older B next to a 47 or newer B, the 44 is going to look smaller cause it is. I think that is one possible explanation.
Steve Crum
08-29-2007 09:32:43
Don't suppose he had the 'little B' confused with a model H? could be easy to do.
old
08-29-2007 09:22:19
Well they made the unstyled and the styled. The unstyled is smaller in many ways and less HP
