1949 JD B Under pressure..
Lloyd1 in CT
08-29-2007 07:42:11
I experience internal engine pressure,enough to puff the valve cover. It seems to have pressure at the oil cap while running. Can I put a breather cap there and relive it,or is there a clog thatI missed somewhere. There is a pipe that comes off the valve cover to the air breather dosn't seem to relieve the pressure-
Lloyd1 in CT
08-30-2007 07:33:28
 Re: 1949 JD B Under pressure.. in reply to Lloyd1 in CT, 08-29-2007 07:42:11
The engine has approx 200 hours on it, no smoke or internal issues. I will check the vents that are there, but it seems to build up over time. It runs trouble free for the first hour or so,then it tends to build pressure.
ET
08-30-2007 07:18:34
Blowby from worn pistons and rings or stuck rings can cause to much crankcase presure.
Mike M
08-30-2007 07:18:30
Or is your engine shot makeing too much blow -by ?
buckeye al
08-29-2007 14:10:06
There should be a fresh (filtered) air inlet pipe from up at the air cleaner back to the ventilator pump at the governor end of the fan shaft. This ventilator pump should be pushing fresh air into the crank case & may actually be working. It cold actually be in part the soruce of the pressure you find at the filler when it's running.
The air pushed "in" to the crank case by the pump is supposed to exit the valve cover through a tube that goes into the side of the air pipe bolted to the front of the carb so that all those fumes are burned up after they're purged from the crank case. I would be checking this tube for clogs because even if the ventilator pump was not functioning, the crankcase should still "vent" through this tube into the air intake. Without the ventilator pump, it would not have the fresh air purge action going on but it should still vent here!
Later.
Lloyd1 in CT
08-30-2007 06:40:20
 Re: 1949 JD B Under pressure.. in reply to buckeye al, 08-29-2007 14:10:06
Not sure but I dont recall any pump at hte end of the fan shaft,either way the pipe from the vc is there and clear,I will have to double check the connection and see if the opening in the vc is clogged but thats waht I was wondering..Thanks for the ideas
rla
08-29-2007 09:33:50
The tractor is equipped with a crank case Ventlation pump located at the rear of the fan shaft, I must not be working at all??
