JD A Water Pump Pulley
MRC
01-23-2000 20:36:03
The water pump on my '51 A is leaking so I'm in the process of removing it to either replace it or rebuild it. The pulley on the pump shaft has a hex set screw wich came out easily, however I have not been able to pry the pulley from the shaft, even after using heat and liquid wrench. It appears that the pulley fully covers the end of the shaft, so I don't think a gear puller would be effective. My understanding is that their are different water pump configurations on different A's. This particular pump has a "51" in the casting as well as the letters LC, B, and numbers 200 and 204. What is the proper way to remove this pulley.
STMTS
01-24-2000 19:22:50
 Re: JD A Water Pump Pulley in reply to MRC, 01-23-2000 20:36:03
A hyd. press and a bearing splitter
STMTS
01-24-2000 19:26:48
 Re: Re: JD A Water Pump Pulley in reply to STMTS, 01-24-2000 19:22:50
BUT these water pumps ARE VERY easy to BREAK so you might consider having someone that does it all the time. There is a special way you have to do this
