830 3 cyl. hyd. noise update
Michael Sheik
08-29-2007 05:17:48
I ran her last night for 4 hours brushhogging and she still does the noise thing as I talked about in yesterday mornings post. I also noticed that after it is good and hot that the pump up front whines. There is no noticable change in how the hydraulics work. Just a note that this thing has power steering so don't know which pump up front would be whining.
Big question here is should I just get over it and run it because everything works good or am I asking for a problem letting it go.
Tx Jim
08-30-2007 03:09:45
 Re: 830 3 cyl. hyd. noise update in reply to Mike M, 08-29-2007 05:17:48
Mike you are correct in saying it's open center. It has a gear pump. Two gear pumps if equipped with power steering. SCV's are unique to 820,830 and early 2040's as they had 3 hyd lines and were all open-center. Maybe his tractor has a leaky rockshaft valve. Tx Jim
Mike M
08-29-2007 05:59:22
 Re: 830 3 cyl. hyd. noise update in reply to Michael Sheik, 08-29-2007 05:17:48
How bad a noise ? wish I could hear it.
If it is really bad ,like a squealing relief valve, I just wonder if that model has an open center pump ? and if someone stuck a selective control valve ( remotes ) off a closed center model ? but then it shouldn't work right either ? Does your hyd. oil seem to heat up fast ? indicating a leak or relief valve problem.
Michael Sheik
08-29-2007 06:48:05
 Re: 830 3 cyl. hyd. noise update in reply to Mike M, 08-29-2007 05:59:22
As far as the volume of the whining noise it is not screaming but can be heard at full throttle. Hate to seem stupid but how do I tell if the hydraulic oil is heating up fast?
As far as the remote is concerned, it looks exactly like the parts book shows it from JD but that doesn't mean anything.
Mike M
08-29-2007 07:06:57
 Re: 830 3 cyl. hyd. noise update in reply to Michael Sheik, 08-29-2007 06:48:05
I don't want to panic you,but if you do actually have a problem I think it should be taken care of before it gets bigger. That does sound a little abnormal to hear anything over a full throttle engine. I would just hold my hand on the lines and the tranny case ? The case should be big enough it should stay pretty good. But those lines should heat up really fast if a problem exsists. The small dia. ones are pressure oil. I would think you should normally be able to touch them and hold on , but with a problem it should get really hot so you can't touch it.
Was your 3pt. still chattering ?
hopefully someone will come along and offer better help.
Michael Sheik
08-29-2007 09:15:27
 Re: 830 3 cyl. hyd. noise update in reply to Mike M, 08-29-2007 07:06:57
The 3 point would only chatter if the clutch pedal was completely depressed to engage or disengage PTO and yes it did it last night twice.
Mike M
08-29-2007 10:57:20
 Re: 830 3 cyl. hyd. noise update in reply to Michael Sheik, 08-29-2007 09:15:27
That model 830 is a different animal than the other models similar to it. It appears to have open center hyd. but still has a trans. pump. I'm not familar with them at all,but generally open center hyd. systems are quiet unless a relief valve is opening from high pressure build up. I don't know if on that model the trans. pump also is required to feed the front pump or not ? Usually an open center pump can suck up it's own oil supply and a closed center pump cannot.
I would tend to agree something isn't maybe ? quite right since you hear it over the full throttle engine noise. A factory JD service manual is going to be needed and I'd start in the trouble shooting section and check some of the pressure settings.
Also ask around any local dealers if they have worked on many of these and see how they normally act.
