4430 cab mounts
charlesmm
08-28-2007 23:47:02
I need to replace the rubber cab mounts due to exessive noise, Is this just a matter of jacking the cab slightly , while not straining the gear levers, or is there more , this is my first step in making it quieter. tia
Will Herring
09-01-2007 11:10:44
 Re: 4430 cab mounts in reply to charlesmm, 08-28-2007 23:47:02
You don't happen to have one of those bad cab mounts that causes excessive shifter vibration do you? I'm sort of worried about the 4430 I was driving the other day. The 1-4 shifter vibrates when at certain RPMs and speeds.third party image
charlesmm
08-29-2007 03:15:28
Thanks for the help, The tractor is just significantly louder than my 4230, it has less baffles in the muffler, cos the 4230 is non turbo and very restricted , and advice on this forum says start with the mounts, then try lead on the firewall and cowling round the steering wheel, then a lead lined floor..... experts say mounts are the best first try.
lonzo
08-29-2007 00:25:33
I unhook the gear shifters if it's a quad range, lift the engin hood and then jack up the cab just enough to do the repairs, i wach the hydraulic controls and if they start getting tight i unhook them and jack the cab farther up. I would like the know what kind of noise you are hearing.
