730 clutch pivot bolt
730virgil
08-28-2007 20:09:06
at next to bottom on clutch lever is what called is clutch pivot bolt. how do you get the old one out? i have have been told is driven in ? or is it threaded parts book shows 2 special nuts used. i need to replace it as i can't get clutch to disengage do to wear in pivot bolt.
730virgil
08-29-2007 07:21:46
 Re: 730 clutch pivot bolt in reply to 730virgil, 08-28-2007 20:09:06
thankyou guys that makes sense with what i already have been told. i have the smaller pin ordered. hopefuly i can drive tractor to welding shop by replacing small pin as it isn't good idea to drive tractor in present condition and i have corn crib door to prove it.
John T
08-29-2007 05:46:15
My old Missouri buddy M L Aylward who posts here sells a puller or you can fabricate one and on tractors where you can get to it we use a blunt ended punch on a vibrating air impact hammer n they push/vibrate right out. The pin is knurled on the end and presses in there. You can try some heat to expand n cool n contract buttttt be careful n dont break the end off. You generally need BOTH the pin and a bushing in the end of the handle for a good tight fit.
John T
MSM
08-29-2007 02:38:53
It has to be pressed out,or pushed out with a gear puller,if you try to drive it out there is a good possibility the casting will break.You'll also probably find out the pivot in the lever is worn out also.
