3020 gas fuel pump leaking
Illinois Farmal
08-28-2007 19:30:19
This afternoon I noticed gas leaking from the fuel pump on my 3020. The fuel pump on my 3020 doesn't have a solenoid on it as I've seen some mention. It seems to be leaking from what appears to be a small weep hole. What's involved in fixing this? Thanks.
JMS/MN
08-29-2007 08:28:35
 Re: 3020 gas fuel pump leaking in reply to Illinois Farmall, 08-28-2007 19:30:19
Gas leaking from the weep hole is an early indication that the diaphragm is going bad. Other idea about changing oil is good- you may be 'gaining' oil in the crankcase because of the leak.
K.B.-826
08-28-2007 19:39:33
There are several brands of pumps that were used on those tractors, and some of them were rebuildable. Today, the typical fix is to replace the whole pump. It's about $40. Make sure to check/change your engine oil, because when these pumps start leaking, the fuel has a direct path into the crankcase. Never heard of one with a solenoid, perhaps you are thinking of the shut-off soleniod on the carb.
