'50 A Power Lift question.
njs
08-28-2007 18:57:20
After replacing the seal and gasket and putting it all back together (no oil to speak of), I find that it seems easier to lift the piston by hand than it did when I took it apart (with oil). I am concerned that maybe I need 1/4 turn more preload on the spring loaded shaft end. I seem to recall that there was more spring load on the end bearing (cap) when I took the last of the 3 screws out of the end cap to pull out the shaft and spring. Can one have too little or too much spring load? Hope this is clear to someone.
Thank you!
Mike M
08-29-2007 04:37:17
 Re: '50 A Power Lift question. in reply to njs, 08-28-2007 18:57:20
I think I have to use a pretty large adjustable wrench to lift one up.
