JD 40
twincreeks
08-28-2007 18:28:29
I`m looking at a JD 40. Sheet medal is outstanding it runs good, but when I put in reverse there is a thumping sound. It does not do it in the other gears. It almost sounds like the 3 point hitch arm hitting the tire. What could it be. The price $1500.00 is it worth it.
jCarroll
08-29-2007 06:54:20
 Re: JD 40 in reply to twincreeks, 08-28-2007 18:28:29
Depends..... ..
The T and the S were common - the U a little scarcer - then the W - and then the hi crops for the rarity factor.
If it needs tires that's another $400.
If it has lights, that's worth $150.
If it has rear wheel weights, that's worth $100.
Does it have the original generator, or an alternator?
You'll have to split the tractor to work on the tranny. My only guess about the noise which would NOT be the tranny is a broken brake disc which thumps in reverse. Try lightly applying the brakes when in reverse to see if that changes the noise.
See if the TOM holds an implement (or weight) with the engine shut off. If it settles down, then you have another project.
If you like the tractor, then it's not a bad price point. I don't think it's one you could do a little work on and resell for a big profit.
Mike M
08-28-2007 18:32:11
I don't know ? but maybe it could have a tooth off of reverse ?
Which model 40 ? tricycle would be worth the least a high crop the most.
