Turbocharged 3010
Big 3010
08-28-2007 17:14:42
Anybody out there ever put a turbo on a 3010 or 3020? I am thinking of doing it to mine. Any replies would be appreciated.
Daryl from Louisiana
09-04-2007 11:28:59
 Re: Turbocharged 3010 in reply to Big 3010, 08-28-2007 17:14:42
I have a 1965 3020 that has been turbocharged for 11 years and have had no problems. 23.1x26 tires from combine, it's 11000 pounds, and pulles a 1630 disk 11'7". I did put a button clutch in it. I bought it used and rebuilt the engine, I would do it again in a heart beat.
buickanddeere
08-30-2007 07:04:29
Trade for a 4320, they sell cheap.
duck64759
08-29-2007 09:05:25
Dad added one to his 3010 back in the 70s for local tractor pulling. On the farm it was our light duty tractor, pulling grain drills, silage wagons,cultivating,ect.No heavy pulling on farm as a general rule,just at the tractor pulls.Fuel turned up,propane,big back tires. Never hurt anything on tractor,pulled almost every weekend in summer for years. Those 3010's were well built tractors.
ET
08-29-2007 04:42:00
3010's don't have engine oil coolers on them so they are a poor choice to turbo. You might better find a 4020 or 4010 for the money you invest in the tractor and turbo parts.
msb
08-28-2007 20:19:58
I installed several back in the 60s at the dealership where I worked. The transmission and rearend will handle the extra horses just fine.However it really isn't worth the time and money considering the small gain in horsepower even when changing the injection pump leaf spring.Makes them sound good however.
Dairy farmer in WI
08-28-2007 19:14:46
also you may damage your rear end by putting too much power to the rear. i say if it didn't come with a turbo it can't handle having one.
just be careful
DF in WI
105EB
08-28-2007 17:25:15
M&W made a turbo kit for the 3010/3020. However, you'd best not get very wild with the fuel screw, because about 80 hp at the PTO is all the crankshaft will stand for any amount of time, and even that can be iffy. Personally, I wouldn't do it unless you have a spare crank lying around.
Gerald J.
08-28-2007 19:30:02
 Re: Turbocharged 3010 in reply to 105EB, 08-28-2007 17:25:15
And for that power level, might as well just pick up a stock 4010 or 4020 and have it safely nearly forever.
Gerald J.
