'55 50 Clutch
Jack OH
08-28-2007 12:23:50
I suspect that I have a problem in the clutch area. When I am sitting still, engine running, trans in nuetral, if I pull the clutch lever all the way back the belt pulley starts spinning and you can't stop it without shutting down the engine.
I thought that pulling back on the clutch lever is supposed to stop ths belt pulley. Is there an adjustment I need to make?
Thanks
Jack
John Van Valkenburgh
08-29-2007 01:37:14
 Re: '55 50 Clutch in reply to Jack OH, 08-28-2007 12:23:50
Jack,
Mike is right. There is a "middle" spot with the clutch where the clutch is not engaged. There is some drag however which is normal, and so there is a pulley brake which should be adjusted to press against the pulley at the dis-engaged point. The pulley brake also keeps you from pulling the clutch back too far and re-engaging.
John
1953 Model 50
Mike M
08-28-2007 12:49:02
Just tighten up the belt pulley brake pad adjustment and /or replace the pad if worn to the rivets.
