JD 14t baler modification to remove engine?
YAB
08-28-2007 10:48:56
Has anyone (or is there already a thread) modified a 14T that had the WI engine on it? Is this even possible? Thanks!
jd40an
08-28-2007 16:44:56
 Re: JD 14t baler modification to remove engine? in reply to YAB, 08-28-2007 10:48:56
If you decide to convert to pto, I probably have all the parts you'd need.
Gerald J.
08-28-2007 10:59:11
Without checking a parts book and operator's manual, I believe its fairly simple. Essentially the gas engine drives the flywheel at the same speed that a 540 rpm pto shaft would. So you need a slip clutch and that pto shaft, all standard 14t parts. Last week I saw one driven by 4 horses through that pto shaft drive.
Gerald J.
