Biggest mower a 70lp can pull????
TRUCKJERK
08-28-2007 10:17:04
So what would be the max without over working the tractor??? 7ft,8ft,10ft-?
vf4x
08-30-2007 03:23:43
 Re: Biggest mower a 70lp can pull???? in reply to TRUCKJERK, 08-28-2007 10:17:04
My 70 LPG will handle an 8 foot very well in 3rd gear.
buickanddeere
08-28-2007 16:14:54
3 to 30 ft depending.
TRUCKJERK
08-28-2007 15:07:08
about 2ft high prarie grass. dry.
Ben.So.Tex
08-28-2007 14:59:53
I was running a 6 ft 3 point behind my 60 this past weekend in a VERY tall hay field and It got hot in 3rd gear. The hay was in places was 10ft+, I did some in 2nd gear just to keep it from getting hot. And my 60 engine is in good shape. But it handles the 6 ft great in 2 ft tall weed, now costal grass is a diffrent story too tick. Good luck Ben
johns48jdb
08-28-2007 14:34:25
most of the time you can find some ease place to start in a field to where you could use a 7 ft mower. i run a 6 foot behind an 574 ih with 54 hp diesel and in places its a load on it. like others have said you can always move over a little bit and not cut a full width any way. i'd rather be able to do it that way than to have to mow a large area of ease cutting with a budhhog thats a foot narrower.
CLW
08-28-2007 12:12:09
Remember you don't have to cut the full width. If you have an eight ft. mower in very heavy grass you may need to only cut fout ft. Then in light cutting you can use the full eight ft. 7ft. would be a nice fit for a 70. I wouldn't go more than 8 ft. as you could cause damage to the PTO if you get tempted to "see what it will do".
RobMD
08-28-2007 14:16:15
 Re: Biggest mower a 70lp can pull???? in reply to CLW, 08-28-2007 12:12:09
That's true when working in heavy stuff... BUT, you forgot that the operator has to make the FIRST run around the field the full width! LOL
Mike M
08-28-2007 10:24:14
It is going to make a BIG difference what your trying to mow down !!!!
