830-3cyl. hydraulic noise-Long Post
Michael Sheik
08-28-2007 05:05:16
Changed out the hydraulic oil on the 830 last night. It was a little darker color than the new Hy-Gard I put in but didn't look all that bad. I put in new filter and pulled and cleaned screen. Screen had only a very small amount of fibers embedded in it and I am assuming that was left overs from when JD replaced the brake discs on it a few years ago for previous owner.
My question is that when I had all back together and was hooking up to brushhog and had clutch completely depressed, the remote hyd assembly on right side of seat began howling and vibrating. I looked at the assembly and lever and it was noticably shaking a little. Am I correct in assuming that the pressure release valve is actuating here under this condition and why? As soon as I released the clutch, the noise and jumping stopped and everything worked normal. Kind of reminded me of dad's 4020 3 point when you first started it up after setting a few days and it would jitter and jump when you tried to raise it the first time.
Mike M
08-28-2007 06:29:31
 Re: 830-3cyl. hydraulic noise-Long Post in reply to Michael Sheik, 08-28-2007 05:05:16
maybe give it a little more time and use and see if it gets the air out and works better ?
720 in pa
08-28-2007 05:19:41
the reason that happened was because of the clutch being depressed for too long.the tranny pump does not pump in this condition.
Michael Sheik
08-28-2007 05:39:13
 Re: 830-3cyl. hydraulic noise-Long Post in reply to 720 in pa, 08-28-2007 05:19:41
You say the clutch was depressed too long. It was probably 15 to 20 seconds. I had to give enough time for the guts of the PTO to stop turning so I could put it(PTO) in gear.
