2 or 4 headlights for a 4020
Bob in NC IA
08-27-2007 23:00:36
I thought all 4020's, not 4000's had 4 headlights. My friend said that he thought the really late models may have came out with only 2 headlights like my 2640 has. Who is right? Thanks.
wilamayb
08-28-2007 03:32:57
 Re: 2 or 4 headlights for a 4020 in reply to Bob in NC IA, 08-27-2007 23:00:36
So I thought at one time there was a good rule to the two headlights, but I've since had my rule blown in the water several times. My personal 69 model that was purchased brand new by my father has two headlights (never used) on the fender. The brightness if controlled by the turn knob on the kick plate. I'm not sure if two headlights was offered on the 24V tractors or not? I have seen them with two per side, but it could have been an add on feature.
If you could find an early and late 4020 build option sheets it should help you in understanding whether or not it was optional factory equipment.
I dont have time right now to look at the parts catalog, but sometimes you can figure out things like this by certain parts being called out for only certain serial numbers. The big break is with the console model in 1969 starting with 201,000. The 69-70 seem to be farily common with each other, but the 71-72 models seem to have more in common with each other than they do with the 69-70. I didnt realize until recent years all the differences in early and late console models.
When you get some time dive in here and see what you can find.
MSM
08-28-2007 01:02:04
Mid run 1971's came out with 2 headlites and a dimmer switch
Bob in NC IA
08-28-2007 06:27:31
 Re: 2 or 4 headlights for a 4020 in reply to MSM, 08-28-2007 01:02:04
You both seem to be on to the answer. My 1969 has 4 headlights and I thought that was correct for all 4020's. However, the 2nd tractor that I was looking to buy is a 1971 powershift. I remember saying to the owner that I'd never seen a dimmer switch on the left side of the platform. So the tractor must be correct and I wouldn't have to change it. Were the 2 light models as bright as having the 4 headlights? I prefer to look of having 4 headlights. Thanks for your help.
