Brake rivets
GoJDpuller
08-27-2007 19:37:35
Where can i get a tool to put the rivets in for the brake shoes on a styled b? or do i have to take them to a shop?
G/MAN
08-30-2007 07:35:42
 Re: Brake rivets in reply to GoJDpuller, 08-27-2007 19:37:35
Take them to a machine shop with a rivet press and stand there and watch the guy rivet on both pads in about 2 minutes.
GoJDpuller
08-28-2007 14:26:01
thanks for the help
Dave H
08-28-2007 04:52:57
I did mine like Kurt recommended
Bob
08-28-2007 02:50:27
The link below has been posted on here several times. I have enever dealt with them myself, though.
Third Party Image
P Browning
08-28-2007 04:22:31
 Re: Brake rivets in reply to Bob, 08-28-2007 02:50:27
Bob -- the tool you show DOES NOT WORK! It is too light. I TRIED IT! I say only -- if you are going to buy a riveting tool to use for tractor brakes, don't buy this $twenty-dollar something. You need more. (PatB)
Mike M
08-28-2007 05:03:08
 Re: Brake rivets in reply to P Browning, 08-28-2007 04:22:31
I have one similar to that one I got from J.C. Whitney and it worked ok ? Don't try to pound them too tight. I was lucky to stumble accross and old foot operated unit from an old auto repair garage and use it now as you have better control.
P Browning
08-28-2007 06:32:45
 Re: Brake rivets in reply to Mike M, 08-28-2007 05:03:08
Mike -- The particular one in the posted link is collecting dust on a shelf in my shop. The threaded part which provides the press is too weak. Also -- it won't fit into the rivet location for a JD-H shoe without substantial modification. There are better ones on the market -- as you have learned.
Kurt and some others have the right idea. A suitable transfer punch, a bench vise, and a helper plus an "easy-does it" attitude -- all key! (PatB)
Mike M
08-28-2007 07:23:25
 Re: Brake rivets in reply to P Browning, 08-28-2007 06:32:45
That's funny it does say it is threaded,but doesn't look like it in the photo ?
The el cheapo I have is just smooth inside and it just guides the punches you drive with a hammer.
P Browning
08-28-2007 07:45:21
 Re: Brake rivets in reply to Mike M, 08-28-2007 07:23:25
That probably would have worked for me. Thanks for the come-back. (PatB)
RobMD
08-27-2007 20:56:50
Forget brake riveting. Forget John Deere original brake linings too! Forget spending too much on your brakes and wasting time.
I take mine to a heavy duty truck shop, and they glue custom linings on for 7 bucks a shoe!!!!! !
The glue has held on my 520 for about 12 years now.
Kurt_JDB
08-27-2007 20:21:48
Takes two people, but you can put a 1/4 inch punch in a vise to use as an anvil, and then have someone hold the brake shoe and pad with the rivet head on the punch in the vise. Then use a 5/16 transfer punch to set the rivets. Few light taps on the transfer punch should do it. Don"t get it too tight. Start with the middle rivets.
Kurt
almrm
08-28-2007 05:46:15
 Re: Brake rivets in reply to Kurt_JDB, 08-27-2007 20:21:48
Kurt,
This method worked great for me. You are right, you need a partner. One side is done and the other will not come apart. Dropping the brake unit on a hard wood block has not separated the gear from the spline so far. I have been applying penetrating oil whenever I walk up to the bench, but haven't tried it for about 2 weeks. I would rather stay away from using heat if I can. BTW has the B's always had straight linings that you bend in assembly? My last replacement on my A was with precurved linings. I did have them in spare parts for about 10 years. Are they all straight now? Just curious.
Regards
Mark
Mike M
08-28-2007 07:30:05
 Re: Brake rivets in reply to almrm, 08-28-2007 05:46:15
Try dropping it from higher up and/or force it down at the same time. I have got some nasty rusted ones apart before , but have not needed to resort to pullers. I don't think I have used heat either , but you may need to heat the gear some ?
Kurt_JDB
08-28-2007 06:42:48
Mark,
I have never seen straight linings. All the ones I have seen are very rigid and are curved.The ones I got from Deere were this way and the after-market ones were this way. Where are you getting these from?
Kurt
almrm
08-28-2007 06:55:19
 Re: Brake rivets in reply to Kurt_JDB, 08-28-2007 06:42:48
Kurt,
This is odd. I was sure they were John Deere. I will check tonight and pick up the part number. They did bend to the contour just fine working from the center out as recommended earlier.
Mark
Kurt_JDB
08-28-2007 07:02:26
 Re: Brake rivets in reply to almrm, 08-28-2007 06:55:19
Mark,
Might be a good idea to have flexible linings. I know the ones from Deere were prone to cracking after they were reformulated without asbestos. I got the last ones from Deere about two years ago. How hard are they to bend?
Kurt
Mike M
08-28-2007 07:27:07
 Re: Brake rivets in reply to Kurt_JDB, 08-28-2007 07:02:26
I have had the same problems as you. I like a$$ bestes !
Mine have always been curved and the later ones prone to cracking.
55 50
08-27-2007 19:55:00
try McMaster-Carr
