1935 B needs fine tuning
Russell S.
08-27-2007 18:48:07
My 35 Unstyled B is running great after a complete restoration. Thanks to all that helped me along the way. I do have a small problem. While running at half throttle or more it is spitting back thru the breather. Kind of a popping sound.It isn't doing it bad but enough to anoy me.What is causing this and how do I stop it?
Mike M
08-28-2007 09:25:45
 Re: 1935 B needs fine tuning in reply to Russell S., 08-27-2007 18:48:07
I can't hear exactly what you are , but on some of these 2 cyl. models more so on the older ones I think you do tend to get some popping back through the intake at times of no load.
So it could be "normal" and nothing to worry over ? But I can't say for sure ? More of this kinda stuff appears after you get all the other noises fixed. Put a straight pipe on and screw up the gov. gears and bearings add some loose fylwheel knock and you will never hear it.
Russell S.
08-28-2007 09:37:18
 Re: 1935 B needs fine tuning in reply to Mike M, 08-28-2007 09:25:45
Mike, That is exactly what I was thinking. Just needed a little nudge from somebody else with more experience.
Thanks
Mike M
08-28-2007 10:15:48
 Re: 1935 B needs fine tuning in reply to Russell S., 08-28-2007 09:37:18
Is it more of a light girgling of the oil in the air cleaner ???? This may be more of what I was talking about ?
Like the others said a lean mixture can make it worse and even a pop.
Russell S.
08-28-2007 16:58:34
 Re: 1935 B needs fine tuning in reply to Mike M, 08-28-2007 10:15:48
I got to investigating tonight and I think the popping in the breather may be caused by the valves not being adjusted correctly. I have a rocker that is really tapping loud like it is way out of adjustment. Could this be the problem?
Mike M
08-28-2007 18:23:25
 Re: 1935 B needs fine tuning in reply to Russell S., 08-28-2007 16:58:34
Anything is possible ? I like to reface the rocker arms paying attention to keep the original curvature to the face. Then set the clearance to .022" cold. Might be a good idea to prelube the rockers good too as it takes awhile for oil to get to them I think ?
wilamayb
08-27-2007 19:56:34
Sometimes running a little to lean on the idle mix screw will cause a fluttering engine at mid idle. I'm guessing it clears up as soon as the engine gets in load? Did you clean your carb yourself? If so do you remember seeing some teeny tiny holes inside the bore on the side nearest the intake manifold? It is possible that one or more of these teeny tiny holes is ever so slightly plugged causing the carb not to be able to pull as much gas as it needs through the idle circuit. Even if you drilled the passages they cant work unless the little holes in the side of the bore are clear of obstructions.
Have you checked your ignition timing?
This is where I would start, unless you have other symptoms?
Good luck!!
