JD R WEIGHT?
ALAN IN SD.
08-27-2007 17:29:17
GOING TO RESTORE MY FATHERS R THIS WINTER. WONDERING HOW HARD TO GET TRACTOR WEIGHT DOWN SOME FOR PULLING. ONE BOOK I SEE SAYS WEIGHT IS 7400 LBS. IS THIS ANYWHERE EVEN CLOSE TO THE REAL WEIGHT? OUR WEIGHT CLASSES ARE 7500 ,8500, 10000 LBS . 7500 AND 8500 WOULD BE BETTER FOR AMOUNT OF POWER. ANY HELPFUL HINTS ON GETTING A LITTLE MORE THAN STOCK POWER FOR THE R. WE LIMIT HP TO 33% OVER STOCK AND RPM,S 10% . THANKS FOR ANY HELP.
Mike w J
08-27-2007 19:41:51
 Re: JD R WEIGHT? in reply to ALAN IN SD., 08-27-2007 17:29:17
My son has an R with pumps turned up stock injecters I think he can pull 8500 lbs class . He can pull up to 10000 lb class. He weighs about 300 lbs The tractor does real good for what it pulls against mostly 4010s 806s He has 18/4/34 tires. Where in SD are you from He is from north east of madison?
ALAN IN SD.
08-28-2007 10:18:52
 Re: JD R WEIGHT? in reply to Mike w J, 08-27-2007 19:41:51
THANKS FOR THE INFO. I LIVE NEAR ABERDEEN. WHO DID YOUR PUMP WORK?
skip33652
08-27-2007 18:52:45
with hydraulics and pto the R won't go below 7800lbs. That is with 18.4 6 ply tires. 8 ply's go up 16.9 's might go down a bit. with a smooth cover you can get one down to about 7200lbs. a stock r is pretty lame compared to the 80's and 820's or a lot of other 8500 lb tractors.but for low gear pulls may hold up .
with pumps turned up all the way you might get 60 horse out of it.with 730 pistons and tips that # can go up to about 75 which would be about 133% of the factory horsepower rating.makes for a real fun tractor Paul in western sd.
