Hi guys, I have a John Deere 110 with a charging problem. I just rebuilt the engine after a rod failure, and on reassembly she runs great, but the battery is not charging. I have poured over the Kohler manual at>Link I do not know the year, but I think it MIGHT be 1967. I can grab the serial number if you can tell me where to find it. It has an 8HP Kohler 181S, a coil, a starter/generator, and an external voltage regulator. My battery only shows around 9 Volts when running (I had to jump to get it started) and voltage steadily decreases. I would like to begin testing the V/R and S/G, but until I can figure out what I have and a matching diagram I am a bit stuck. I will tell you what I know: The starter/Gen has two terminals labeled A and B. The Voltage Reg has four terminals-- one on top, and three on bottom, with another one which simply grounds the unit. Other than the standard coil, points, plug, and kill switch so I can't start with the deck engaged, that is about all there is save a generator light. Anyway, help me identify what I am working with and then we can start testing. Thanks! ~Brad
