820 clutch adjustment
Mark Bohne
08-27-2007 15:08:16
My clutch grabs and is impossible to smoothly start in higher gears---I pulled cover, undid 3 castellated nuts, only finger tight, with cotter keys on, and pulled all those steel rotors and linings out. Boy this tractor was really built!! I found no oil, just thick black packed dirt like stuff, The rotors were smooth and shiny. The linings were 1/8 thick clean and shiny.The springs were all the same and still springy. The fixed pins were kinda grooved on one side-1/2 inch low then 1/2 inch higher some--I tried to pull out with vise grips, but these were so hard, that they laughed at the vise grips. I bet these are pressed on? I did not take off the biggest rotor.I was able to clean up the inside of the belt pulley pretty good.
What do you recommend to fix up rotors and linings?
_____ _____ _____
Swiss manufacture it,
French hoard it,
Italians squander it,
Americans say it's money
Hindus say it does not exist,
You know what I say-
I say time is a crook--
peter lorre 1954
Edit/Delete Message
