JD 410 B Pump not destroking
Jason Haburt
08-26-2007 20:59:57
Hi all I have a 1985 JD 410 B. The problem I"m having is when your not using the hyd the engine is being loaded down,and and the system gets hot. I have tried replacing valve o-rings,hoses,filters,valve spings,The one backhoe valve is hissing,and goes away if you pull back a little bit. Is that my problem. Is the valve bad? Is it the destroke valve? Thank You Jason
Bob
08-27-2007 00:16:30
 Re: JD 410 B Pump not destroking in reply to Jason Haburt, 08-26-2007 20:59:57
Repair or replace the hissing valve.
Jason Haburt
09-24-2007 20:07:30
 Re: JD 410 B Pump not destroking in reply to Bob, 08-27-2007 00:16:30
Thank you for you help. anyone know were to get used or cheeper backhoe valves Thank you Jason
