JD 544C fuel prime
netman
08-26-2007 13:59:09
Have a 544C and fuel ran dry. Have tried bleeding air at filter and pump. started once and cut off. I'm pretty sure it still has air in lines but need help with all the bleed points.
Randy S
08-26-2007 14:43:21
 Re: JD 544C fuel prime in reply to netman, 08-26-2007 13:59:09
Bleed it at the injectors. Loosen the injector nuts about a turn and crank over til you see a good flow of fuel.
Dave in Tx
08-26-2007 20:32:20
 Re: JD 544C fuel prime in reply to Randy S, 08-26-2007 14:43:21
should be a lever on the mechanical pump to pump fuel thru the filter bleed screw.
