Had something odd happen. Backhoe has started immediately and run great since I bought it 2 months ago. I was using it at my farm this week, dug 250+ ft of trench with no problems. Had no indication of anything going wrong. Went to start it in the morning and it acted like an old car that needed the gas-pedal pumped. Started and ran fine for 2 hours. I shut it off for probably 4 hours, then when I went to start it, it wouldn't do ANY-thing but grind. Maybe water in the fuel system? I'm new to diesels and have very little experience, but am fairly capable (mechanic-wise) with the right info. When I get back up to the farm I'll change the filter and maybe change the fuel pump (original). Is there anything special I need to do in the way of bleeding the fuel lines as if I was replacing the injector pump? Thanks in advance Ken 1937 JD unstyled B 1957 JD 60 1959 International Cub 1968 Allis Chalmers I-400 1981 JD 310AD PS: I've been a "lurker" on this forum for a long time and just wanted to say that you guys are really knowledgeable and have been helpful to me more than you'll ever know! ;-)
