B Wheels
CalJim
08-24-2007 16:06:44
Anybody ever hear of 36" Pressed Steel Wheels? They are not in my JD Unstyled parts book. CalJim
WTW
08-27-2007 07:32:54
 Re: B Wheels in reply to CalJim, 08-24-2007 16:06:44
2010 John Deere tractors were available with 9 bolt 36" press steel wheels. Look in the 2010 parts book for part numbers. I run these wheels on my unstyled "B" pulling tractor. They were available in 11" and 12" widths. DW
pmg
08-25-2007 12:51:32
 Re: B Wheels in reply to Gary from Muleshoe, 08-25-2007 04:13:31
Gary. are you from Muleshoe Texas? If so, what are all those tractors lined up along the road on Highway 70 between Clovis and Portales? Also saw some more in Hereford I believe. (I live in Michigan now)
Gary from Muleshoe
08-25-2007 12:55:50
 Re: B Wheels in reply to pmg, 08-25-2007 12:51:32
They are all lined up there because the owners have them way overpriced. The ones near Hereford (at the Friona airport) all went through a tornado some years ago, they parked them all outside and would not sell a one of them. I am told the son has started selling a few here and there, but they are still way overpriced.
Gary from Muleshoe
08-25-2007 13:00:01
 Re: B Wheels in reply to Gary from Muleshoe, 08-25-2007 12:55:50
PMG
I have a sister that lives near Detroit.
momsworry
08-25-2007 05:13:19
The A became styled I believe in 1939. I own a 40 and it is styled.
Gary from Muleshoe
08-25-2007 12:58:42
 Re: B Wheels in reply to momsworry, 08-25-2007 05:13:19
I said you all would prove me wrong. Was the A available either way in the early years? I thought I had seen some as late as 41 unstyled.
P Browning
08-26-2007 06:38:02
 Re: B Wheels in reply to Gary from Muleshoe, 08-25-2007 12:58:42
Gary -- Some of the confusion may come from the actual make up of the 39 & 40 "A" tractors. In many ways, they are much like the Unstyled tractor of 1938, but with a new set of tin! It is almost as if the 39 & 40 tractors were "transition" models. These "A" tractors, for instance, have a fuel tank found on no others.
1941 production tractors were the beginning of the new & improved (yet early styled) JD-A tractors. I think the same may also be said of the JD-B tractors.
But it is a fact that "A" tractors went STYLED as we know "styling" starting with 39 production.
I am sure there is piles of data written on these gems in various books out there. Interesting! (PatB)
wilamayb
08-25-2007 15:02:07
Gary, The unstyled general purpose A and B tractors ended in 1938. Some of the early 39 model, styled tractors were orginally unstyled, but they were fitted with styled parts and called 1939 models.
105EB
08-25-2007 13:24:19
Last unstyled "A" was built in June 1938. All model "A" tractors built after that were styled, except the "AR" and "AO" tractors, which weren't styled until 1949.
BMAN
08-24-2007 16:13:42
Yes I have a set of 36 inch pressed steel wheels. They are painted JD yellow so I assume they were on a John Deere. They are between 6-7 inches wide.
