Classic green over Van Sickle
Tired 300 in Mn
08-24-2007 07:15:17
I have a JD 50 that I've been working on. I cleaned, sanded, & wire wheeled most of the tractor. I've been using rattle cans of Rusteoleum primer & painting with Durashield (bottom of cans say Van Sickle). The paint is a month old & seems to be stable. Can I sand lightly & paint with JD classic green without causing problems? I would be using a gun for this. I'm not trying to make a show tractor, it is used for a little mowing, plowing, etc. Thanks for any replies.
Tired 300 in Mn
08-24-2007 19:33:59
 Re: Classic green over Van Sickle in reply to Tired 300 in Mn, 08-24-2007 07:15:17
Thanks for the info. One more question I neglected to ask on 1st post. I have a couple partial cans of Classic green from previous projects. They've been closed as tightly as possible & stored in my basement. Should I try to use them or be looking for a proper method of disposal? Thanks again.
P Browning
08-24-2007 23:08:40
 Re: Classic green over Van Sickle in reply to Tired 300 in Mn, 08-24-2007 19:33:59
That is another good question for Shawn Mahady!
two cylinders saves gas
08-24-2007 20:51:20
It's your decision . lol These guys need harder questions to anwser.
johns48jdb
08-24-2007 11:43:02
you should use a self etching primer on bare metal. it needs to be painted over within minutes if memory serves me right. if you have to wait about paint you need to sand it per manfactures instructions. plan primer may or may not stick good on bare metal.
P Browning
08-24-2007 10:26:23
Rob -- this is a classic paint engineering problem. If you had a JD-H and if you had my Restoration Guide for the H, you would have been advised to inquire! Valspar Paints (I think I am right on this) is the company supplying John Deere Classic Green synthetic enamel to Deere, through your dealer. So you should write to them with this specific question. I have to tell you -- you need to be real specific with the brand names on the rattle cans you have been using -- when asking!
Write to Shawn Mahady, And his e-mail is "smahady" at valspar-dot-com. If this don't make it through the filters, or you can't figure it out -- write me.
Now -- aside from the specifics -- the greater amount of time that can pass between what is applied and what you plan to apply, the better your chances are of success. Frankly, I think you will be okay so long as you are thorough with your final prep before JD Classic Green. But then, let's see what Shawn has to say. Good Question! (PatB)
leon
08-26-2007 05:12:58
 Re: Classic green over Van Sickle in reply to P Browning, 08-24-2007 10:26:23
I'm wondering if Deere didn't change suppliers for rattle can paint about a year ago. Anyhow, there was a time period when most dealers were out of most rattle can paints, and when it finally came back on the shelf again the cans had a different look, the spray nozzles on the cans were different, and I think the paint was even just a slight bit different in color.
P Browning
08-24-2007 10:29:34
Hi Rob -- I got crossed up -- the paint engineering reply was meant for Tired in MN. But the same response is good for anyone. Have a Great day! (PatB)
Mike M
08-24-2007 10:42:40
 Re: Classic green over Van Sickle in reply to P Browning, 08-24-2007 10:29:34
Speaking of you getting crossed up ? where's FIT ? LOL
P Browning
08-24-2007 10:55:34
 Re: Classic green over Van Sickle in reply to Mike M, 08-24-2007 10:42:40
Hi Mike!
(PatB)
RobMD
08-24-2007 09:21:25
Well, I have painted several parts with rustoleum or krylon primer and a Deere topcoat before, but I would never paint a whole tractor with that primer.
I just wonder if the color might show through when you paint it.
I am positive though, that you should be able to do a good job if you carefully painted it with the primer.
