How many watts can 4020 alternator handle
nylon
08-23-2007 22:31:31
I have 4 55 watt halogens on the front of the cab and 3 55 watts on back. Total is 385 watts. Wondered if this would draw too heavy. Been working fine so far but had to replace 2 lights on back and think that they were not 55 watts...just regular implement lights.
G/MAN
08-25-2007 13:27:49
 Re: How many watts can 4020 alternator handle in reply to nylon, 08-23-2007 22:31:31
If your tractor has an alternator, it is almost certainly a 12-volt system throughout, regardless of the number of batteries involved - there should always be two on a diesel. The 4020 diesels with generators used a 12-volt/24-volt system with a 24-volt generator and a 24-volt starter, with the rest of the electrical system using 12-volt components and divided into half - one battery running each half. During starting, the batteries would act in series to crank the engine. Converting that system to 12 volts involves installing an alternator and a 12-volt starter. So with an alternator, your tractor has either been converted or is new enough that it left the factory with a straight 12-volt system. Wattage = volts x amps. A 55 watt light being supplied with 12 volts would therefore require just under 5 amps, actually even a little less since no 12-volt system working properly should ever drop to 12 actual volts. 13.5-14.2 is the system voltage norm if the alternator is supplying enough current to meet the load needs and keep the batteries up. Having 4 lamps of 55 watts each means a draw of around 20 amps, in theory. Then you have to consider voltage drop due to wiring, etc. But a 20-amp load is a good approximation. Various amperage alternators were used depending on tractor age, model and equipment - cab tractors with A/C had much bigger alternators to power the blower and condensor fans. Ones with the bare minimum of lighting and no cab got by with a much lower rated alternator. A tractor with no cab and optional lighting like most have would fall in the middle - two front fender lights on each side, a rear work light, flashers, etc. What you can safely add for electrical load depends on the alternator you already have. Just as important as the lights themselves is how they're wired. If you're using tiny cheap wiring, a single switch (don't even think about splicing into the original lighting harnesses and switch), substandard connectors and pretty much plan on clustering the wiring together however is easiest, you may as well give up now. Use quality wire of the proper gauge for the load and length of wire required, fuse the circuits, ground the lights to a good solid chassis ground, and consider using a relay or relays to power the lights so that a simple toggle switch of unknown quality isn't carrying all of the load. Doing all of this after making sure the alternator is of sufficient capacity, of course. Just off the top of my head, I think I'd want at least a 72-amp alternator under the hood for what you want to do. That way there will be sufficient charging system capacity to run all of the various lights at once for an extended period of time with no risk of draining the batteries or overloading the alternator. There is no such thing as too much alternator, and the more amperage capacity the alternator has, the longer it will live and the better the whole system will perform.
[Reply
JMS/MN
08-24-2007 12:01:24
The alternator should have an amp rating on it- 35, 55, 70, etc., or at least a part number that tells you what the output is.
Gerald J.
08-24-2007 09:33:27
Need more information. Is it 24 volt or 12 volt, the original generator or an alternator? There is a great deal of difference. The original generator at 24 volts was only 10 amps, 240 watts for all the lights and battery charging. And you have to balance the + and - 12 volt lamp loads or you won't even have a chance at charging both batteries.
If it had a factory airconditioned cab, then it could have had a 24 volt alternator. But if its side console it may have had a 12 volt sytem with alternator.
There may be a nameplate on the generator or alternator with ratings, but likely not.
It is possible to ask for more power than the dynamo puts out and to work that way for a while, but eventually the batteries will run down and you won't start again without external charging.
Gerald J.
Brian Setlak
08-24-2007 00:51:52
Take you're total number of watts and divide by the volts and that will tell you the number of amps the lights are drawing. Ohm's law. 385/24=16.04 amps. If you have a 24 volts system
nylon
08-24-2007 10:49:51
 Re: How many watts can 4020 alternator handle in reply to Brian Setlak, 08-24-2007 00:51:52
I have a 2 battery 12 volt system. That means I am drawing 32 amps?
JD9295
08-26-2007 06:38:57
 Re: How many watts can 4020 alternator handle in reply to nylon, 08-24-2007 10:49:51
uh no. that means you have a 12 volt system with two batteries.
add up all the WATTAGE your drawing on the system and dived by 12 thats your amperage.
Just out of curiosity, where did you get the 32 amps at?
G/MAN
08-25-2007 13:09:46
