70 All Fuel
Scarecrow
08-23-2007 21:33:33
I recently purchased a 70 All Fuel and the small starter tank (AF1253R)is missing. Is this the same exact tank that is on a model G? Also my water pump has a factory hole on one side that someone has forced a hose barb with attached hose into. It then runs to the upper water pipe which someone has drilled a hole and welded a small piece of pipe to and attached the other end of the hose. Did the 70 all fuels tend to run hot? Is this the wrong water pump or the wrong upper water pipe? If someone would happen to have a picture of a complete 70 all fuel that would be very helpful. Especially the small tank area and fuel line setup, since mine is incomplete and would like to see what it is supposed to look like. Thanks
Scarecrow
08-24-2007 16:45:21
 Re: 70 All Fuel in reply to Scarecrow, 08-23-2007 21:33:33
I am almost positive it is an all fuel. I am still waiting on my research. It has an all fuel hood, all fuel block (F1305R) with petcocks, 3 way fuel valve, and one piece manifold. I cannot find this type of water pump in my parts manual. I also noticed that the thermostat was missing.
buickanddeere
08-24-2007 07:52:53
Farmer fix bypass line. It may also have been running too cold. Check all the part numbers on manifold, carb, head, block, fuel valves etc. Most 70AF for sale USED to be an AF. Some SOB tried that one on me. I called the shop later. Yes they did happen to have a AF 70 block/head/manifold/three way valve for sale, just came in. Tractor Jockeys have a dirty habit of pulling the AF parts off, selling them to tractor pullers. Then installing gas head, gas manifold & block etc. Then selling it to you with a straight face saying it's an AF70.
