JD 300 conversion to 3 pt
TDrewcock
08-23-2007 18:43:49
I have a 1969/70 JD300 backhoe and I was wondering if anyone has put a 3pt on this unit when the hoe is off. I know it is supposed to be very similar to a 1020 ag tractor. But does the trans/diff housing suppport a 3pt conversion?
Cheers!
tdrewcock
09-03-2007 20:38:05
 Re: JD 300 conversion to 3 pt in reply to TDrewcock, 08-23-2007 18:43:49
Thanks for all your help guys. Cheers
jdemaris
08-24-2007 05:26:46
It IS basically a 1020 - with a few changes, e.g. the hydraulics. 1020 and 300 three-point hitch parts are the same- and many 300s came with the hitch. My 300 has the hitch. You can strip the necessary parts off a 1020 or a 300 and it will work fine.
buickanddeere
08-25-2007 19:30:12
 Re: JD 300 conversion to 3 pt in reply to jdemaris, 08-24-2007 05:26:46
If memory serves correctly, the three point hitch rockshaft assembly was a "common design" and used on several models of JD tractors besides the 1020. Cross referencing in the JDparts site shows many duplications.
