Its illogical compared to a tractor with two or three shift levers for as many transmissions cascaded. Its a logical way to shift though. Its one three shaft (plus an idler shaft for reverse) transmission, partly shifted by gear sliding, partly shifted with synchronizing clutches. All through cams selected by the left or right position of the shift lever. Push the shift lever to the left. You are shifting ranges, four of them. Not synchronized so you only shift while standing. Slowest with the lever forward, fastest with the lever to the rear. To the right after picking a range you have two speeds forward and in three of the four ranges a reverse gear. These are synchronized so can be shifted (with the clutch pushed) while in motion. In the lowest range you have 1,3, and reverse. Second range gets you 2, 5, and reverse. Third range has 4,7, and a super fast reverse that is fragile. Fourth range has 6 and 8 and no reverse. Park is the range side all the way front, tow is marked. Never tow the tractor without shifting the tranmission to the tow position. Doing otherwise will destroy the gears and bearings on the top shaft in seconds. Gerald J.
