Flywheel tightening 'A'
ld
01-23-2000 10:28:41
I had to remove the flywheel to replace the crank cork seal recently and in order to get the bolts off had to cut them with a torch. In replacing the flywheel I find I am unable to tighten the new bolts enough to keep the flywheel from clucking on the shaft. Someone told me there is a special 1 1/8 wrench for this- Is this available or are there any other tricks to accomplish this feat?
Shorty Dear
01-23-2000 12:06:36
 Re: Flywheel tightening 'A' in reply to ld, 01-23-2000 10:28:41
I have a fly wheel wrench for the model A. It also fits the G and D. E-mail me if you are interested. If you had a flywheel wrench, you wouldn't have had to cut the bolts off to begin with.
