CRANK
ROUGH ENOUGH 1
08-22-2007 20:05:46
DOES ANYONE KNOW WHO AND WHERE TO GET A JOHN DEERE 2 CYL. CRANK STROKED. THANKS
lonzo
08-24-2007 11:17:44
 Re: CRANK in reply to ROUGH ENOUGH 1, 08-22-2007 20:05:46
Stan Blade,417 732 7275 crank shaft work
Earl - IL
08-23-2007 08:06:13
If you could let us know where you live we can send you to a shop in your area. Here in Illinois we have several shops who can stroke to to 9- 10 in. Earl
P Browning
08-23-2007 07:35:14
Give Russ a call over @ Paul's Rod & Bearing. He's one of those guys who will cordially chat with you without making you feel you owe him something! His number is (816) 587-4747. This way you get some ideas plus perhaps some new avenues to persue. (PatB)
wilamayb
08-23-2007 06:49:02
I went to a place in Nashville, TN called Standard Motor Company. I was there for a Mack engine, but I noticed a 2cyl block there. I inquired about it and the technician explained that they were going to add deck height to the block to make room for a stroked crank. I'm not sure that they do cranks, but they can do some extreem "custom fitting". Their specialty is large diesel engines, but they will do just about anything. Give them a call. I'm sure they can be found in switchboard.com
lonzo
08-23-2007 04:13:45
yes there is a guy west of springfield Mo, I can't think of his name right now but i had him grind crank that nobody else would even look at.IF i can think of it today i will look him up for you
