2010 wiring
D. Keller from
08-22-2007 16:33:32
Anyone out there know how to wire a 2010 without a voltage regulator using a generator. I know the A and B terminals from the VR need to be tied together but do the F and L terminals also get tied together?
dobber
08-23-2007 09:33:42
 Re: 2010 wiring in reply to D. Keller from MO., 08-22-2007 16:33:32
Is there a VR hidden under the dash or hood? It may have been once unhooked for a alternator conversion?
Bob
08-22-2007 19:59:40
WHY would you want to run a generator WITHOUT a voltage regulator??? (OR, are you installing an INTERNALLY-regulated alternator?)
If you tie the "F" and "L" terminals together, a LOT of smoke is gonna get let out of the system!
Also, you need the "cutout" function of the voltage regulator. Otherwise, at shutdown, the battery will completely discharge through the generator, ALSO releasing smoke!
(Were you a LUCAS engineer in a past life?)
soundguy
08-23-2007 05:18:20
 Re: 2010 wiring in reply to Bob, 08-22-2007 19:59:40
Bon you bring the popcorn, I'll get the soda's.. Looks like there will be fireworks tonight!
Hey D. Keller.. why not sell that genny on ebay instead of sacrificing it over open flame...
Soundguy
Dave Keller
08-26-2007 02:03:30
 Re: 2010 wiring in reply to soundguy, 08-23-2007 05:18:20
Hey soundguy come sit in the seat when I fire it up and lets see what kind of sound we can get out of you then. I'll pop your corn for ya. Yee hah. A real barn burner.
John T
08-22-2007 17:46:58
Since you mention an L terminal I take the Voltage Regulator to be a 4 terminal with BAT FLD LOAD and ARM terminals and often the one off on one side or the bottom all by itself is the ARM terminal.
FLD on VR to gennys Field post ARM on VR to gennys ARM post BAT on VR wires up to the Load (NOT battery/starter) side of the ammeter if it has one or else the hot ungrounded battery post LOAD on VR feeds hot batery voltage up to loads like Lights n Ignition often via being wired to their BAT input terminals
Polarize the genny before you start her up
John T
Dave Keller
08-26-2007 01:54:50
 Re: 2010 wiring in reply to John T, 08-22-2007 17:46:58
JOHN I AM USING AN INTERNALLY REGULATED ALTERNATOR AND SOME ONE HAD WIRED THE TRACTOR WITH OUT A VR. I HAD IT STOP RUNNING ON ME AND I HAD SEVERAL WIRES THAT HAD COME APART IN THE WIRING. I AM TRYING TO FIGURE OUT HOW THEY WOULD GO BACK TOGETHER. I THINK THE BAT AND TERMINAL 2 ON THE ALTERNATOR ARE TIED TOGETHER AND GO TO ONE SIDE OF THE AMMETER AND THE OTHER SIDE OF AMMETER GOES TO THE STARTER/+TERMINAL OF BATTERY. #1 TERMINAL OF GOES THRU A CIRCUIT BREAKER AND THE GEN LIGHT TO THE IGNITION SWITCH BAT TERMINAL. THE I TERMINAL ON IGNITION SWITCH GOES TO THE COIL. THE S TERMINAL ON SWITCH GOES THRU THE STARTER SAFETY SWITCH TO STARTER SOLENOID. THE L TERMINAL TO THE LIGHTS. THE IGNITION SWITCH HAS 3 TERMINALS ON THE SWITCHED SIDE THAT ARE HOT (BAT,I AND L)AND THE INTERMITTENT ONE TO THE SOLENOID.
DAVE K.
Bob
08-27-2007 09:00:40
 Re: 2010 wiring in reply to Dave Keller, 08-26-2007 01:54:50
WHY are you "shouting"? We aren't the ones who "mucked up. YOU did, in your first post, telling us you had a "GENERATOR"!
soundguy
08-27-2007 04:41:24
Your first message stated you had a genny.. not an alternator. BIG difference. Also.. sounds like you have a delco 10SI type.. which DOES have an INTERNAL vr.
Sounds like it is wired right.
#1 to key switch thru lamp.
#2 to bat connection.. etc..
Soundguy
