4020 gear shifter
Jeff Oliver
08-22-2007 07:54:59
Can you replace the older style handle on a synchro range with one of the newer handles that is taller? Mine is the shorter one and it is awkward to use and I was thinking if I can swap them I'll get one of the taller ones.
Thanks!
msb
08-22-2007 23:10:54
 Re: 4020 gear shifter in reply to Jeff Oliver, 08-22-2007 07:54:59
If you are talking about the longer shift levers used on 5010s,5020s and 4320s, yes, they will work on a 4020. I have changed them over for customers in the past.
Kent Petersen
08-22-2007 20:04:08
there is no way a power shift lever will work on a scyro tractor get a lever for 71 or 72 scryo it will do what you want lol Kent
brd620
08-22-2007 14:58:09
yes, but it will bump into your pto handle,will have to get a get a handle off a powershift tractor
Jeff Oliver
08-22-2007 18:43:16
 Re: 4020 gear shifter in reply to brd620, 08-22-2007 14:58:09
That is even better. I know a guy who took 2 powershift tractors and made one and both have the long handles. The subject is wrong on this as it is a 3020 instead of a 4020. I was having one of those mornings when I posted that I guess...
Dave H IA
08-22-2007 11:37:31
Yes
