JD 24 T balerMeasuring wheel arm
lafnwatr
08-21-2007 14:41:07
The measuring wheel arm on my 24T baler broke into 2 pieces in the field. The JD dealer has all the surrounding parts but not this one. Anyone have a source for the part? The part number is E14747E
Thanks!
JDD
08-23-2007 16:23:31
 Re: JD 24 T balerMeasuring wheel arm in reply to lafnwatr, 08-21-2007 14:41:07
Guy parting out a 24 t on ebay right now. Link to
http://cgi.ebay.com/John-Deere-14T-24T-Hay-Baler-PICKUP-TEETH-276SE_W0QQitemZ170141016236QQihZ007QQcategoryZ66879QQssPageNameZWDVWQQrdZ1QQcmdZViewItem his ad.
Bob
08-21-2007 15:37:17
You might try dropping the "E" at the end, and having the dealer run it on the locator.
Otherwise, it's steel, and certainly could be welded.
lafnwatr
08-21-2007 20:24:50
 Re: JD 24 T balerMeasuring wheel arm in reply to Bob, 08-21-2007 15:37:17
I think they did run it without the E. I just listed it that way because it is on the actual part. They found the part but as I understand it, JD no longer stocks it. As for welding, one side is missing somewhere in the field.
Bob
08-21-2007 21:35:24
 Re: JD 24 T balerMeasuring wheel arm in reply to lafnwatr, 08-21-2007 20:24:50
I looked on ebay... there have been a seller or two listing 24T parts this spring and summer, but NO luck.
Hopefully, someone with one sitting in a tree row will respond!
If not, is there enough left that the missing piece could be fabricated, and welded on?
I USED to have a 24T, and, as I recall, that's a PRETTY SIMPLE part, and I'll bet it can be repaired.
lafnwatr
08-24-2007 06:30:38
 Re: JD 24 T balerMeasuring wheel arm in reply to Bob, 08-21-2007 21:35:24
Thanks for these ideas. I'll pursue ebay. I really appreciate the help
