3010 road noise? bearing? brakes?
Dexter travis
08-21-2007 13:46:10
I have a 3010 diesel. In road gear it makes a kind of grinding noise that seems to grow louder and softer at about the same speed as the tire goes around. It is coming from the rear somewhere. Is it in the tranny, a bearing, brakes rubbing, or am i completely heading in the wrong direction. Tractor has been in the family for a long time considering retiring it to parade/tractorcade usage any idea what kind of money I am looking at to fix or is this something I should just look the other way on. I do not notice in other gears at lower speeds but will not say for sure that it does not exist. Cannot miss it going down the road. Any help or advice appreciated.
Dean Barker
08-22-2007 08:54:22
 Re: 3010 road noise? bearing? brakes? in reply to Dexter travis, 08-21-2007 13:46:10
I think that you are hearing normal gear noise that comes from slightly inaccurate tooth profiles. I wouldn't worry about it. My 4320 has a similar noise when going down the road in 8th gear.
Bob
08-21-2007 15:38:45
Check that the rim is tight to the center, and the center is tight on the axle. If so, jack up that side, and see if there is play in the wheel bearings.
