730d trans/differential/clutch
bruce schepler
08-21-2007 11:41:58
need some help figuring out strange noise coming from my transmission-rear diff/clutch. when pulling under a load, i hear strange noises coming from the work platfrom. its not the engine and does not make strange noises when the clutch is engaged out of gear. could something be low on oil? do i have a gear or bearing going out? i am assuming this tractor has alot of hours on it. any ideas? thanking you in advance. bruce
Kemper
08-21-2007 17:37:37
 Re: 730d trans/differential/clutch in reply to bruce schepler, 08-21-2007 11:41:58
Could something be low on oil?
Yeah could be,that would be a good place to start.
Is this a tractor that you just bought? some of them are just noisy.
Mike M
08-21-2007 12:18:42
I have seen alot of 2cyl. tranny's and very seldom do you find one that is not in need of attention. The lower countershaft bearings will be going bad and/or way out of adjustment at the very least on about 99 of 100 tractors. It is simply amazing what you can find if you go looking.
bruce schepler
08-21-2007 13:42:48
 Re: 730d trans/differential/clutch in reply to Mike M, 08-21-2007 12:18:42
how much of a repair job is it?
Mike M
08-21-2007 19:29:06
 Re: 730d trans/differential/clutch in reply to bruce schepler, 08-21-2007 13:42:48
VERY MAJOR on a diesel.
2cylinderlp
08-22-2007 10:17:22
 Re: 730d trans/differential/clutch in reply to Mike M, 08-21-2007 19:29:06
third party image
Mike, why is the transmission a bigger job on a diesel? I did my 730LP trans last year and it had all kinds of problems.
Mike M
08-22-2007 10:42:12
 Re: 730d trans/differential/clutch in reply to 2cylinderlp, 08-22-2007 10:17:22
THAT'S THE WAY TO DO THEM !!!!! Everything out in the open.
A diesel is even more of a PIA because the LH side cover is 1 pc. for engine timing gears and all. And it fits up under the governor housing. More places to leak from and for the best seal everything should come off and then you find even more problems.
msb
08-21-2007 12:03:53
First thing I would do is jack it up and check the axle bearings.See if you can wiggle the wheels. Have you ever greased the axle bearings? Most people don't do it.
wilamayb
08-21-2007 17:10:27
 Re: 730d trans/differential/clutch in reply to msb, 08-21-2007 12:03:53
MSB, I have to laugh. It seems as though you are right most folks never grease them, but there is the guy that keeps a zerk in the hole greases it every time he gets on the tractor.
I learned a new reason a couple weeks ago for greasing those axle bearings. I felt like it would be greedy to keep it to myself. So I'll share. An old man with a 630 had leaky axle seals. He was joking about selling the tractor to me. My reply was "I cant buy that thing the axle seals are leaky. It will get my shop messy" His reply was "Oh that leak happens every once in a while, but I've figured out that if I put enough grease in the axle bearings it slows it way down from a drip drip to a drip drip drip" Then he smiled with the smile that you can invision. I just thought I should share with everyone at least one more reason to grease those axle bearings. LOL!!!!! If nothing else I grease mine just to keep Exxon in business. I know they have been hurting as of the late! HA
msb
08-21-2007 12:03:46
