1947-Model M-trouble staying running
Eva M Robinson
08-20-2007 16:37:23
My father-in-law is having trouble with his 1947 Model M John Deere. It will start fine, but after a few minutes, shuts off. Starts fine again , then shuts off again. Seems it shuts off after heating up. He's having difficulty mowing Texas grass after a lot of rain and my mother-in-law is having a hizzy looking at the tall grass. Help save a 56 year marriage!!!
Mike M
08-21-2007 07:09:20
 Re: 1947-Model M-trouble staying running in reply to Eva M Robinson, 08-20-2007 16:37:23
If after it dies and you have no spark try a NEW condenser. If after it dies and you have spark but no start try checking the fuel flow and look for something floating around in the tank clogging it up.
donwisc
08-20-2007 17:28:06
Sounds like you have all the synptoms of a bad coil. Try checking for spark when it shuts down the next time.
Eva M Robinson
08-21-2007 06:20:10
 Re: 1947-Model M-trouble staying running in reply to donwisc, 08-20-2007 17:28:06
Thanks for responding so quickly, but he has already replaced the coil.
two cylinders saves gas
08-20-2007 16:48:36
Air , fuel , and spark, is all u need to run these old tractors. Should be something easy.
Clair Worley Jr.
08-21-2007 12:42:38
 Re: 1947-Model M-trouble staying running in reply to two cylinders saves gas, 08-20-2007 16:48:36
Take the Valve out of the fuel tank and Clean the fitting, then remove the fuel line fitting into the carberator and clean it. Also you may want to by pass the switch and jump the battery direct to the coil. May be a bad Ing. Switch.
