48 m timing
jon w.
08-20-2007 14:16:14
48 m can and will the timing slip and where is the most proable cause? when it starts it sounds like it fires only on one cyl. thanks
Dave H
08-20-2007 16:57:30
 Re: 48 m timing in reply to jon w., 08-20-2007 14:16:14
Jon
How do you know you have a timing problem if you have not checked the time. The ops manual will tell you how to do it both static and with a light.
If it has not been worked on yet, I bet it is just a fouled rear plug. Find out which plug is not popping, then check to see that fire is getting there, then replace the plug.
Bet that may work
jon w.
08-21-2007 11:07:28
 Re: 48 m timing in reply to Dave H, 08-20-2007 16:57:30
checked plugs both fire with good blue flame, had carb rebuilt, still nothing,,,thanks
jon w.
08-23-2007 09:37:54
 Re: 48 m timing in reply to jon w., 08-21-2007 11:07:28
it was the gas , cleaned it all out good and now runs great,,,,, thanks
