JD 300 Hydraulic shut off
TDrewcock
08-19-2007 23:18:17
Hey Guys, I have just been given a JD300 backhoe by my uncle. He gave me the rundown on it and a few things seem a little weird to me. 1) He showed me a hydraulic shut off valve on the pump that I have to shut off in order to get enough cranking speed to start the engine (3cyl diesel) Is this normal? Not to mention when the valve is open it leaks.
2) Can anyone give me direction on where to find parts for the linkage for the backhoe pivot and what parts I may need to tighten it up. You can miss the hole your digging by about 3ft. Not good it tight spots.
3) Does anyone have a good system for counterweight when the backhoe is off. It won't even pull itself up a small incline without slipping the rear tires. Cheers folks!
Roy Suomi
08-20-2007 18:31:34
 Re: JD 300 Hydraulic shut off in reply to TDrewcock, 08-19-2007 23:18:17
You can wiggle the steering back and forth to relieve hydraulics for an easier start while cranking the engine..[Or any not lifting hydraulic function] Just enough to relieve starter stress..The "Tee" handle up front can be backed out till it seats so the leak is stopped or seriously slowed down..I've found that if the "Tee" isnt backed all the way out , it'll leak thru the threads..
jdemaris
08-20-2007 09:09:53
Yes, needing the destroker is normal. When new and everything perfect, it isn't needed. But once well used, just about any John Deere with closed-center hydraulics develops small internal leaks that cause very hard cranking. Many of these leaks are small "nuisance" leaks and don't cause any trouble, otherwise. A bigger leak can lead to overheating of the hydraulics. I worked for several Deere dealers since the 1960s. We had many tractors that needed the destrokers when new - otherwise the starter motors had short lives. In regard to the backhoe linkage - I suppose you've got the odd-ball single swing cylinder linkage setup? Can't you get the parts from Deere?
Mike M
08-20-2007 06:44:14
Our old crawler had a counterweight that when the hoe was off it fit into the brackets just like the hoe. You tiped the bottom in first then we ran a chain to the loader bucket or used a chain hoist to raise it up and put the top pins in. You might luck out in junk yards and find one ?
In warm weather you shouldn't need that pump destroker valve to start it. You may have a bad high pressure leak or just a bad starter and or cables ? JD may just be the only source of parts for these.
