rattle in front of block 1947 model a
Steve Kelly
08-19-2007 19:25:17
this tractor has excellent oil pressure and runs great. i can not tell if it might be a wrist pin or a push rod. It pops every now and then thru the exhaust and back fires every now and again. It does not sound like a rod knock on the crank end it's more in the front of the block towards the top of the pistons. Oil pressure almost to high side of gauge.
P Browning
08-20-2007 13:18:41
 Re: rattle in front of block 1947 model a in reply to Steve Kelly, 08-19-2007 19:25:17
Steve -- Two things:
(1) Oil pressure should be adjusted so that it falls between 10 & 15 pounds. The limts are between the "M" and "H" marks.
(2) The last engine I had that exhibited some "knocking" at the forward end of the cylinder block was stricken with a sloppy fit between pistons and bore. It was time for over-sized pistons and over-boring the cylinder block to match the new pistons. This type of knock is best discerned under a load at low engine speed.
The wrist pins on two-cylinder tractors seldom are found to be loose enough to make a noise. Oh -- it happens, but not often. And push rod noise is also not common. And so the puzzle may be solved quickly by a micrometer and one skilled in it use to measure bore and also pistons.
I would like to add here -- For the engine I found this anomaly with, it had really very good compression inspite of nearly 0.020-inch disparity (wear) between bore & pistons! So a compression check won't help much on this one. (PatB)
Steve Kelly
08-23-2007 18:51:30
 Re: rattle in front of block 1947 model a in reply to P Browning, 08-20-2007 13:18:41
I don't know if this is what it is. but it may be possible someone has just been in the head because it has the new lead washers under the bolts. it has quite a bit of compression and it is popping thru the carb. a little and it is also hard starting. I guess i will have to go a little deeper. I removed the plug wires and the sound does not differ any. thanks for the information.
