G/MAN
08-19-2007 21:26:46
Re: Brass Tag, what makes 'em special? in reply to Bob, 08-19-2007 18:39:30
That's pretty much wishful thinking by those that are hung up on brass tags and the supposed increase in value that a brass tag warrants. Mostly they want a reason why their belief that a brass tag makes a tracor more desirable and valuable is valid, which isn't based in fact to any extent. From what I've read and heard, Deere's production records and the info that can be obtained from them pretty much are what they are, and some tractors were better documented than others, for whatever reason. I highly doubt that whoever was keeping the books on a certain day took the trouble to find out what the serial number tag was made of, and any info recorded about the average tractor coming down the line would have been that provided to the person keeping the records, and nothing more. Certainly Deere didn't get carried away on the details beyond what was absolutely necessary to get the tractor built, properly equipped, identified, located on the grounds until it was shipped, loaded and shipped to its intended destination. Of course there were probably exceptions, such as if the tractor had a very unusual option or options, was headed to a special destination, was going to be used at a testing facility or by farmers for testing on their farms, etc. Compared to what's available for most other brands of old tractors, Deere did a heck of a job with their records, but it wasn't a huge priority then, and they certainly had no inkling that 50 years later some person that wasn't even born yet would care about every little detail about the "birth" and early life of his "A". For the average Deere tractor with average equipment going to the average farmer - one of umpteen thousand pretty much identical to it - there just wasn't that much exciting to keep track of There is way more info available from Deere for any tractor built in the last 20 years or so compared to what they kept then, thanks to computers, new technology and vastly more complicated machines making all sorts of information necessary for convenient access by dealers. The tags themselves were also changed a lot over the years - location, materials of course, how they were made and tooled, what was painted, printed or stamped on them, etc. And without knowing for certain exactly how many tags would be required for a specific model run, there is no way that Deere was ordering tags in huge lots and keeping umpteen thousand of whatever tag in stock just because they "might" have needed that many. That would have been wasteful of time, materials, labor, inventory space and money. It's pretty likely that they were ordered and produced in relatively small lots to cover estimated demand for a certain time period or for a production run of known length or up to a specific serial number and number break for a running change. That one lot of tags could have been produced from one material and the next from another, or maybe came from a different supplier if they were sourced from outside Deere & Co. A new lot of tags would come in and be put in inventory, and as the old stock was exhausted or a run of a different or new model came down the line, the new ones of different material would have gone on a run of tractors until they were used up or another change was made. Regardless of who was making them, Deere might have given them several material options and instructed them to use was was cheapest or in largest supply of the size and type of stock they needed to make the tags at the time. The serial number tags were and still are important on several levels depending on what these old tractors are used for and who owns them, but absolutely crucial to the machine and its operation as a whole they weren't, and Deere never took major steps to make sure that a machine's identity was super secure. As far as Deere & Co. was concerned, the serial number tag on the average production tractor was there to give each machine a unique i.d. for building and paperwork purposes, denote its place in production if a running change was made at a particular serial number break, and keep track of it until it left the factory and reached the dealer and customer. At that point the machine was no longer the factory's worry and it was up to the customer and dealer to make sure the machine kept its i.d., was properly serviced and repaired with the correct parts, and that any needed improvments or warranty repairs were done and the records of the work received by Deere if Deere was responsible for covering costs and reimbursing the dealer. Deere's recommendation still is and has pretty much always been that the customer should keep good written records of his machine and pertinent info, because the fact is that a serial number tag provides about as much security for the machine itself as writing it on the side of the hood with crayon would, should someone be of a mind to alter, destroy or remove the tag. Anyone that's had a tag or entire machine stolen can attest to that. It's much better these days, because the machine's identity is present in the controller software and can't easily be changed or tampered with, but smart owners still keep hard copies of all of that stuff in a safe place. That's the only way to do it when you're dealing with something that's really valuable but has no title to go with it.
