I PREVIOUSLY POSTED THE BELOW ABOUT POPPER FLYWHEELS and I have at least 1 for a "B" I would give you if you would pay the shipping from Rusk, Texas. How to fix popper FLYWHEEL/CRANK splines posted by ellis brasher on July 14, 2003 at 17:49:03: In 1982 I bought a 520 out of a junk yard to rebuild and it had a lot wrong with it including a very loose flywheel (FW). I priced a crank and FW at the JD house at about $850 so that started serious thinking. I had a friend that had a large lathe and he charged about $35 for the required machine work. You may know that the FW side main is 2.249" dia. and that the crank must be able to slide in the pressed in main. Now you must measure as close as possible how much of the crank sticks out of the FW with the so called lock nut off and with the FW set for the minimum thrust clearance which is .005". The first thing I did was use some mild steel weld rod and weld in and fill in the grooves of the splines on the crank and even put at least one pass on the spline lands. Be sure to protect the main bearing surface. It doesn't matter if you mess up the threads on the end of the crank and in fact it is better to just weld over the threads. I then let the machinest machine where I had welded to the same size as the main bearing and then machine off the end of the crank the amount that was previosly measured. The next thing is to remove the FW starter gear and have the machinest use the starter gear lands to line up the FW in the lathe and then bore it so that it will just barely slide on the machined end of the crank with the two tightening bolts removed. Now comes the hard part. Assemble the crank in the main bearings with the thrust washer in place. Set the crank so that No. 1 is on TDC and figure out a way to secure it at this point. Install the slinger/spacer and related parts and then slide the FW on the crank, install, but do not tighten the FW bolts. Next install the FW cover so that you can the turn the FW on the crank so that the timing marks line up for TDC. This is important due to the FW having balance weights built in. Once you get it timed, carefully tighten the FW bolts to barely secure it; and the machined face of the FW should be even with the end of the crank. Now you must hand drill and tap 6 holes for 3/8" N.C. socket head cap screws. Evenly space 3 on each side of the FW parting crack. Drill at the parting line between the FW and crank and keep in mind the crank is harder than the FW so the bit will try to wander to the FW. Start with new bits, use a 5/32" first then 1/4" and then 5/16" which is the final size. And you should have a regular and a bottoming tap. It doesn't matter if the drill bits wander off a little and they do not need perfect spacing. Drill and tap as deep as possible without going past the inside face of the FW. Before tapping be sure to recheck the thrust clearance and correct before tapping if needed. The last thing you will do is tighten the FW holding bolts. Mine has been running 20 years and I did let it get loose about 8 years ago and I then drilled out 3/8" and tapped for 7/16" cap screws and kept poppin. [email protected] MAYBE YOU WOULD RATHER HAVE A TOP FUEL DRAGSTER In 1962-65 I built and drove gas and fuel dragsters and I will provide a link/picture of the car I drove in 1964. It will be a color picture before the long story about one of the 6-7 cars I built while living in CC,Tx. Link Story of labor, dedication and fun!! In late '64-'65 my friend Bill Rogers inquired about building a HEMI(R) powered dragster and having built about 4-5, I already had most of the required equipment and material on hand. This first picture is of the roll cage and the bending required, but only tack welded. The car assembly requires bending all four frame members, front axle, roll bar and brace and the steering box mounting bracket. The first car I built, the tubing was hauled from CC, Tx to the Rio Grande valley for bending and it turned out looking about like exhaust tube bending. I then started think about how to make decent bends in 1.5" O.D. X .050" wall frame rail tubing and 1.625" O.D. X .125" wall roll bar and front axle tubing. Actually I always used 1�" IPS SA-106-B steel pipe for roll bar and axle, it being 1.66" O.D. X .140" wall. I wanted the bends to be about 7" inside bend radius so I started thinking about bending it around a piece of 14 " pipe, but I knew it needed something to prevent it from collapsing/kinking. I solved the collapse/kinking problem by machining a solid steel, egg shaped object that would barely fit inside the frame or roll bar and axle tubing. It was set up on a steel welding table with a piece of 14" pipe about 4" long mounted on an axle vertical to the table so that the tubing could be secured to the 14" pipe and the 14" pipe rotated in order to cause the tubing to bend. To prevent collapsing and kinking the "egg" was welded to a 20' piece of 1/4" pipe and the "egg" inserted inside the tubing to the point where the bending occurs and the 1/4" pipe secured so the "egg" would remain where located while the tubing slides over it during bending. The entire bender was made from 4-5 pieces of scrap and was manually operated; I will draw, scan and post a sketch of the bender if anyone wants to make one, [email protected] Below is a link to the cage picture: Link I have added this link to show a sketch of the bending apparatus: Link The next shot is of the back end of the car. The scatter shield was made from a steel, 1/4" min. thk. 14" pipe cap with a flange welded on to fit the engine bolt pattern. Look close at the bottom and note the clutch release fork shaft that sticks through and through; drilling the 3/4"+ holes on either side for a smooth fit of the shaft ain't very easy. You may notice a new scatter shield pipe cap lying in the background. Link The next shot is also the back and also shows the 392" HEMI(R) block. The object between the scatter shield and rear end housing is a homemade lineup jig made from pipe and machined to fit the main bearing saddles, scatter shield bearing housing and rear end pinion bearing housing. The rear end is an Oldsmobile, junk yard variety that was narrowed by torch cutting and welding. A lineup jig was used to keep it close. Some axles were shortened by torch cutting and welding; some were resplined and heat treated. Link This next shot is from the engine to the rear. Here it gives an idea of how the frame tube bends look and keep in mind that no two of the frame rails are alike. The uprights were fish mouthed to fit the rails using a hole saw the same size of the tubing; the fits must be good in order to stick weld .050" wall tubing. I would normally put the first pass with a 3/32"Lincoln Fleetweld 180 rod and then cover with a 3/32"Lincoln Fleetweld 37 rod. Link Next is a shot of the car frame full length and as I recall it was 180" wheelbase. The torsion bar was made from a junkyard VW torsion bar that came laminated by using stacks of 1/8" X 3/8" steel bars, but the normal was to use the correct number to make a 3/4" square bar and then use 3/4" drive sockets welded to the arms bolted to the axle. The trick was to locate and weld the sockets on to get both sides built with the same setting on each arm. Link The next is the front end and lots of hours in hand making each component including wheels; hubs machined from solid aluminum 3.5"diameter bar so as to accept tapered roller bearings, spokes were intended for wheel chairs and the hub caps were freeze plugs. The spokes were installed and tightened using a dial indicator so that very little balancing was needed. Negative camber was about 3 degrees and caster about 30 or so. I still have the spoke hole drilling jig. Link Next is a shot of the car on a borrowed trailer for the first time and I think it went to the old Houston track on the Gulf Freeway. As I recall the car ran 3 runs at 215+. The guy with the white hat on and with the big bulls eye is the owner/driver. Any doubts he could get in it. Link Next shot appears to be a very important conference; the two guys with writing on the T-shirts are the co-owners; guy with the shades is Blackie Blackard (RIP), Blackie. I took the picture, but don't know where, probably Houston. I think the guy with the funny looking hat is Tom Crowley who I built a car for which appears on the near side in the match race 2 pics. below. The guy leaning on the rollbar is present day starter Rick Stewart; I showed him that picture at Houston in '06 and he got laugh out of it. He was running the old Houston track at that time Link Next is a 2 out of 3 "match" race between Gary Watson, near side and Bill in his first ever and Ford powered race car. These "match" races were like the WWF in that no one ever won the first 2 and back then the money was slim pickins. The race was at old Rodd Field at CC, Tx where I and many others saw their first ever big time racers that would come and put on 2-3 exibition runs, the likes of Garlits, Eddie Hill and the twin Pontiacs, Bobby Langley's SCORPION and once with an aluminum channel framed car, Bob Sullivan in Pandemonium and of course half a dozen locals. Link Next is Bill on a run at Victoria, Tx, I think, and at Victoria Bill hit the ET/MPH lights etc. and laid the right half of the front axle back about 30 degrees, had to cut it off and install a new end. Link Next is Bill and Blackie waiting in the push to start line; I think at Green Valley near Fort Worth, Tx. Link Next shot is probably at the Green Valley Spring Nationals which Bill won over the best diggers in Texas. The race was billed as a $5000 dollar race which was probably more than the cost of Bill's car. There was much torn up equipment at the race with two cars becoming entangled at about 200 mph and the Cortines car flipping 7 times, but he walked away. Link Last is a little about the Green Valley race and win. Hope you enjoyed this little dab of drag racing history and one of my biggest regrets is I never spent the time or money to photograph things I have seen since seeing my first ever drag race at Halls, Tn. in 1957 or so where I saw what would later become the "Tennessee Boll Weevil" get beat by Lewis Carden's SBC, NHRA record B gas dragster. A friend and I pulled the Boll Weevil trailer back to Memphis to Ray Godman's home where we met him and I first learned of him being in a wheel chair. Link Here's a couple more made from slides dated Aug, '66. Link Link _____ _____ _____ '51 hemi & '55 sbc; a class of their own. "One Day At A Time" The 12th root of 2 = 1.0594631 A good dog don't sing on a covered trail. As in Cool Hand Luke, "What we've got heah is a fail-ya to communicate." "Shakin' it over here, boss".
